Sonarr version (2.0.0.5322):
Mono version (5.20.1.19):
OS: Ubuntu 18.04
Debug logs: Unable to send test message: The operation has timed out.
I’m running the LinuxServer/Sonarr Docker image and everything is working fine except one annoyance. Sonarr is unable to reach a Kodi box on the same LAN. When I test an added Kodi installation under Connect it times out with the error above. I’m unable to ping the Kodi box from the Sonarr container, so I believe this has something to do with the way Docker handles networks. This may not even be the right place to ask, but I figured someone here has been through this already.
