I am new to Nzbdrone and I love it.
I would like to know if I can connect Nzbdrone to the Plex Sickbeard plugin.
The Plex Sickbeard plugin was working with the Sickbeard fork that I was using but the developer is going to delete the fork.
I hope somebody can’t help.
Ricky Dominguez
Not sure what that plugin does, but its very unlikely since I imagine it communicates with SB’s API, which is completely different from Sonarr’s, so no.
Thanks for the fast replay Markus,
It’s let you control Sickbeard from Plex, is let you see your shows, what show is next, try to find a show that was not found, you can add new shows, etc.
It would be nice to have a plugin like this to connect Sonarr with Plex.
Its definitely doable, but its not going to come from the Sonarr dev team (same as that plugin likely came from a 3rd party dev), plugin development isn’t our forte and we have a lot to do on Sonarr itself.
If someone is interested in making on the API docs are listed on the wiki.
I know this post is ancient but figured I’d pass a long an update. The sonarr plugin for PMS is here- https://github.com/jamorin/Sonarr.bundle
I’m having issues with the series section not populating, but the rest is on point. Not sure if it’s me or the plugin itself but I’ll take a look at it tonight.
Nice plugin but I do not see how to add a new series via this plugin.
adding a new series hasn’t been added yet. you can only look for episodes for existing series. The plugin is new and I suspect more will be added.
EDIT- Correction: You can add a new series from the sonar plugin in the Plex iOS app, and most likley android as well (I don’t have an android to confirm).
