2021-11-10 15:07:45.4|Debug|Api|[POST] /api/v3/indexer/action/newznabCategories: 200.OK (44 ms)
2021-11-10 15:07:50.6|Warn|SonarrErrorPipeline|Invalid request Validation failed:
-- : No rss feed query available. This may be an issue with the indexer or your indexer category settings.
2021-11-10 15:07:50.6|Debug|Api|[PUT] /api/v3/indexer/9: 400.BadRequest (53 ms)
2021-11-10 15:07:58.5|Debug|Torznab|Downloading Feed http://127.0.0.1:9117/api/v2.0/indexers/concen/results/torznab/api?t=search&cat=8000&extended=1&apikey=(removed)&offset=0&limit=100
2021-11-10 15:07:58.5|Debug|Api|[PUT] /api/v3/indexer/9: 202.Accepted (52 ms)
Can not add conCen indexer unless I also add category 8000 (other) for anime as well, doesnt seem to make sense. When I add to both and do a manual search for tucker carlson jackett logs show my private indexers searching but not conCen, a search directly on conCen return results as expected. adding log text as i cant upload txt doc
Jackett addition is no issue, its adding the indexer to sonarr, wont let me add witout also adding other in anime, most likely not an issue but very odd, then when i search for a series (tucker) jackett log shown it searched my other indexers but not concen.
There’s nothing to do nor would it make sense on Sonarr’s end.
Per Jackett’s defintion it does not support ANY tv or movie search or anything other than basic queries and also does not have any cats other than other - which isn’t a big deal.
