Good Afternoon,
I just switch from Sickrage to Sonarr and for now I can say that it was easy to do the conversion and Sonarr work perfectly except for one little thing !. I have to always manually import from my directory where the Complete download are. I triple check my configuration to be sure that I have the same directory in my Transmission setup that the one in my Manual import section and they are the same , I also check that the complete download is tag to YES and it is.
I really don’t know WHY Sonarr don’t move or copy the file to my Serie library when the download is completed ?
Any clue will be appreciated.
Transmission and sonarr are running on the same Linux computer
Dir in Transmission donwload client /share/Download/transmission/serie/
Complete donwload handling is set to yes
Episode downloaded won’t be copied to my library until I hit the Import manual button and I used the same Dir that I put in the Transmission config /share/Download/transmission/serie/
What did I do wrong ?
Best Regards,
Sylvain
