Cleaning notifications
Version
4.0.16.2946
.NET
Yes (6.0.13)
Windows 11
How does one clear System Health Warnings. I have a message concerning the TVDB which is now out of date by some margin and there does not appear to be any mechanism by which to delete it.
Most health warnings/errors should clear on their own after they are fixed. You can try running the Check Health task, but if the underlying issue persists then it won’t be cleared.
