CIFS importing issue
Sonarr version (3.0.8.1507):
OS: Docker container
Hi guys,
I am having a problem where sonnar and either radarr not moving completed downloads from downloads ditectory to movies folder from where plex is reading.
downloads directory and movies directory are on the same drive shared by OMV via cifs.
I know there is permision issue but i have checked and I from sonnar container cli i can access both folder and write into them. Please help as it is driving me nuts.
[Warn] ImportApprovedMovie: Couldn’t import movie /downloads/complete/abx.mkv
[v4.1.0.6175] System.UnauthorizedAccessException: Access to the path ‘/movies/abc.mkv’ is denied.
—> System.IO.IOException: Permission denied
at System.IO.FileSystem.CreateDirectory(String fullPath)
at System.IO.Directory.CreateDirectory(String path)
at NzbDrone.Common.Disk.DiskProviderBase.CreateFolder(String path) in D:\a\1\s\src\NzbDrone.Common\Disk\DiskProviderBase.cs:line 190
at NzbDrone.Core.MediaFiles.MovieFileMovingService.CreateFolder(String directoryName) in D:\a\1\s\src\NzbDrone.Core\MediaFiles\MovieFileMovingService.cs:line 197
at NzbDrone.Core.MediaFiles.MovieFileMovingService.EnsureMovieFolder(MovieFile movieFile, Movie movie, String filePath) in D:\a\1\s\src\NzbDrone.Core\MediaFiles\MovieFileMovingService.cs:line 151
at NzbDrone.Core.MediaFiles.MovieFileMovingService.CopyMovieFile(MovieFile movieFile, LocalMovie localMovie) in D:\a\1\s\src\NzbDrone.Core\MediaFiles\MovieFileMovingService.cs:line 84
at NzbDrone.Core.MediaFiles.UpgradeMediaFileService.UpgradeMovieFile(MovieFile movieFile, LocalMovie localMovie, Boolean copyOnly) in D:\a\1\s\src\NzbDrone.Core\MediaFiles\UpgradeMediaFileService.cs:line 51
at NzbDrone.Core.MediaFiles.MovieImport.ImportApprovedMovie.Import(List`1 decisions, Boolean newDownload, DownloadClientItem downloadClientItem, ImportMode importMode) in D:\a\1\s\src\NzbDrone.Core\MediaFiles\MovieImport\ImportApprovedMovie.cs:line 123
That error seems to be for Radarr, not for Sonarr.
That aside, try checking here for your container composes and permissions.
https://trash-guides.info/Hardlinks/How-to-setup-for/Docker/
Also https://wiki.servarr.com/docker-guide
