Cant select a network drive location for Add Series
Sonarr version (2.0.0.3934 ):
Windows 10:
Debug logs (posted to hastebin or similar):
**Description of issue (When I try to add a series to this new Sonarr installation it only shows me the native C:\ I can not browse to or manually select a my network mapped drive where I store my content (WDMyCloud)) **:
The FAQ covers this, either use the UNC path (\server\share) or run Sonarr via the startup folder instead of as a service.
I tried both those suggestions from the FAQ site but neither of them worked. Fortunately I tried the universal solution (reboot Windows) and it worked as advertised after that. Not sure why the Sonarr install doesn’t do that but thanks anyway.
