Sonarr version (exact version): Sonarr Ver. 2.0.0.5252
OS: Windows 7
Debug logs: https://pastebin.com/LPiGgG0U
Sonarr stopped downloading nzb files and passing them off to sabnzbd in the last day or so (been working fine for months). It can successfully index/find the nzb file on my search engine, but whenever it tries to download the nzb it errors out. Looking in the log, it’s having an issue with creating an SSL/TLS channel.
I can successfully:
- search for files in Sonarr and see the various options for a particular show/episode.
- search for the files in my search indexer manually and download the nzb file successfully to my local machine.
- sabnzbd will automatically load up the nzb file when it is placed in the monitor folder, and download the file.
It’s just the hand off between Sonarr and sabnzbd which breaks the automation.
I upgraded sabnzbd to the latest version, and checked that Sonarr also is on the latest, and double checked any settings I know to check.
I’ve looked at similar topics here but nothing is popping, so apologies if this error HAS been covered in another topic.
Thanks
AP
