Sonarr version (exact version): 3.0.7.1477
OS: Windows 10 21H2
For quite a long time I’ve had this issue that episodes were downloaded successfully, yet they were marked as missing in Calendar.
A bit weird for me was that some episodes were marked as Downloaded, while others were marked as missing.
Only today I discovered that if I change the “Category” of the torrent from within the torrent client (qbittorrent in this case) prior to Sonarr task that checks for finished downloads had a chance to run, Sonarr will not be able to mark the episode as downloaded.
As soon as I changed some of the “missing” episodes Category back to how it was when downloaded, Sonarr marked the episode as Downloaded.
Example: episodes downloaded by Sonarr are in RSS Category.(setup in Download Client)
Once downloaded, I manually copy them to another location and process them with another software.
To know which ones I have already processed, I manually change the Category to Done.
Any setting I am missing that can make Sonarr not check torrent after it was already downloaded?
Or maybe, any way to make Sonarr mark episodes sooner as downloaded so that me changing the Category will not mess up the downloaded status?
Thank you.
