Automatic handling of failed when using NZBGet
Hey,
I’ve just made an observation that when using NZBGet it dosn’t seem to try and refetch failed episodes, however if i use sabnzbd it works as a charm.
Should this work with NZBGet or is it only supported when using sab? If it should have worked with nzbget aswell, is there any setting i can have messed up?
I am pretty sure it is only currently supported with Sabnzbd @markus101 would of course have to confirm this but i am fairly certain this is the case
Currently it’s Sabnzbd only, you can vote/follow this card on Trello though: https://trello.com/c/eB6ceraa/495-nzbget-failed-download-handling
Am I correct saying that it now also works with nzbget?
@EvtK depends what branch you’re on, only in develop right now. https://github.com/NzbDrone/NzbDrone/wiki/FAQ#i-see-that-featurebug-x-was-fixed-why-cant-i-see-it
