Sonarr version (exact version): 3.0.3.750 Mono version (if Sonarr is not running on Windows): 5.20.1.34 OS: Ubuntu 16.04.6 Description of issue:
I have a video file which was imported a couple of months back on an older Sonarr version and the detected audio channels were 6. Due to some issues, I had to import the file again today and this time the detected audio channels were 5.1.
The mediainfo shows the channel count as 6 for the primary audio track but the arrangement is 5.1. Does this mean that this was an issue earlier which has been fixed now or is there some regression?
I checked the detected audio channels via the info available on the episode section.
Great. Would you mind specifying the commit for the same too?
Am I correct in assuming that the expected behaviour now is that it will consider the channel position too along with (or instead of) the channel count?
Is there any way to force a mediainfo rescan of the already imported content so the audio channels can be corrected? I include the AudioChannels as part of my naming convention and I would like to get them all corrected. A simple refresh doesn’t seem to be accomplishing it even with Analyse Video Files enabled and Rescan Series Folder after Refresh set to Always
