Arch Linux: Sonarr can't connect to transmission
Sonarr version (exact version): 2.0.0.4326
Mono version (if Sonarr is not running on Windows): 4.4.1
OS: Arch Linux
((Debug logs)): http://hastebin.com/texoruzalo.xml
Description of issue: I am unable to connect to my remote VM running transmission from Sonarr on Arch Linux, my Windows install of Sonarr can connect and function just fine, for the life of my I can’t figure it out.
It’s a bug with mono 4.4.1, either downgrade to 4.2 or upgrade to 4.6.
Awesome thanks markus101, managed to upgrade mono to 4.6 and appears to be working.
although installing mono 4.6 wasn’t as easy as I thought it would be…
