Hi!
I have a NAS where my drone factory is \\10.9.0.5\Storage\TV\Drone.
Files import beautifully from there.
If I try with a mapped network drive it doesn’t work - but I’ve read about that, and it is a separate issue.
On my NAS (called 10.9.0.5) I send a request to the Sonarr-server on my network as below.
Command:
curl -o ~/sonarr.log -u mescon:password -X POST -H "X-Api-Key: MyAPIKeyHere" -H "Content-Type: application/json" -d '{"name": "downloadedepisodesscan", "path": "\\\\10.9.0.5\\Storage\\Staging\\complete\\sonarr\\"}' http://10.9.0.11:8989/api/command
Response:
"name": "DownloadedEpisodesScan",
"startedOn": "0001-01-01T00:00:00Z",
"stateChangeTime": "2015-03-26T17:49:44.7047649Z",
"sendUpdatesToClient": false,
"state": "pending",
"manual": true,
"id": 31707
Because this is JSON, I must escape any backslash with another backslash, so \\10.9.0.5\ becomes \\\\10.9.0.5\
The Sonarr user can read the directory without problem. If I specify that path as “Watch Folder” when configuring “Download Client”, the episodes import just fine, but I want to manually trigger the scan in this directory.
When I supply the path from a script to initiate scan manually, nothing ever happens, despite the above output.
The logs indicate no errors at all. If I try with a network mapped drive, it says the path does not exist (another issue, I know).
Whenever I have tried a path that does not exist, I get instant errors (as expected) in the logs.
Am I doing something wrong here, or is there a bug somewhere preventing me from actually setting the path to be scanned?
Any support would be much appreciated!
Thank you!
