Mono Version
4.2.2 (Stable 4.2.2.30/996df3c Thu Mar 17 11:46:47 CET 2016)
OS
DSM 6.0.1-7393 Update 1
I’m wanting to automatically download a particular show that has all been uploaded under the “DSR” quality. I haven’t been able to figure out how to get Sonarr to automate this since there’s no profile option for DSR. Any suggestions?
“DSR” is apparently used a lot when TV shows are ripped from over-the-air stations, however Sonarr does not detect this type of format. It’s very helpful for those of us who want to get classic TV shows that have not been ripped from discs.
Thanks for the reply! The issue I’m having, though, is that Sonarr doesn’t recognize the format since it’s labeled “DSR” as opposed to “SDTV”. Is there a way to get Sonarr to recognize it in a profile?
I just tested a few DSR releases and they all parsed as SDTV, internally Sonarr treats a DSR source as SDTV, both ((debug logs)) and Manual Search/Manual Import (for importing files) should show that it gets treated as SDTV. If you can post logs showing it being detected as something else we can take a look to see why.
