Sonarr version (exact version): 4.0.1.929
Mono version (if Sonarr is not running on Windows): ?
OS: Synology DSM 7.2
Debug logs: Ubuntu Pastebin
Trying to change the root path for existing media/requests to the same actual location, just using correct(different?) pathing. Sonarr/Radarr does not recognize old path as a valid directory anymore and says its ‘already configured’
old root folder: /!!Anime/!!Anime/
New root folder: /hiimawalrusSHARE/Plex/!!Anime
The root folder was never renamed or moved, but I just upgraded and rebuilt all of my arrs along with synologys new 7.2 update and shifting from docker to container manager.
With current mapping Sonarr/Radarr work perfectly fine with newly added media. However with any old media or requests it does not see the old mapping anymore as valid, and when I try to change the root folder it says “Path is already configured as a root folder” even tho I deleted the old mappings and added the new ones.
Anything that was old is unable to import in both radarr/sonarr
System Status message: Multiple root folders are missing: /!!Anime/!!Anime | /!!TV Shows/!!TV Shows
However I have mapped: /hiimawalrusSHARE/Plex/!!Anime
/hiimawalrusSHARE/Plex/!!TV Shows
This is how I mapped the volumes in the old .yaml :
- /volume1/docker/sonarr:/config
- /volume1/hiimawalrusSHARE/Plex:/!!TV Shows
- /volume1/hiimawalrusSHARE/Plex:/!!Anime
New .yaml mappings:
- /volume1/hiimawalrusSHARE:/hiimawalrusSHARE
I pulled the old and new .db file with sql and these are the values under root folder
Old .db file:
1,/!!Anime/!!Anime/
2,/!!TV Shows/!!TV Shows/
New .db file:
3,/hiimawalrusSHARE/Plex/!!Anime/
4,/hiimawalrusSHARE/Plex/!!TV Shows/
I’m positive I goofed mapping and this is 100% my fault but I don’t remember exactly why/how because that was a year ago. Not positive how to fix, thank you ahead of time for any help!
