Am I applying delay profiles correctly?
Sonarr version (exact version): 4.0.12.2823
OS: Unraid
Description of issue: Delay Profile
Hi, I’m trying to understand if I am using delay profiles correctly. I set a delay of 60 minutes for torrents only, to bypass if it exceeds a custom score. It says “This is the default profile. It applies to all series that don’t have an explicit profile.” I see that if I created a second delay profile, I can set a tag. But if I don’t need a second delay profile, does this just automatically apply to all my quality profiles? I don’t see an option in them to reference a delay profile. It seems to me that this is basically saying that if I created a second profile with a tag, and set that tag to apply to a specific quality profile, and if a show was under that quality profile, then it gets the second delay profile, but if there is no tag, it automaticaly, by default gets the first delay profile that has no tag. Is that correct?
The default Delay Profile applies to all series. If you added a second it would apply to all series with a matching tag.
A Quality Profile doesn’t have any link to a Delay Profile, except indirectly through the series.
You don’t need to create a second Delay Profile unless you want different rules for different series.
