Failed to get newznab api capabilities from althub:
17-10-1 09:50:20.8|Debug|NewznabCapabilitiesProvider|Failed to get newznab api capabilities from https://api.althub.co.za
[v2.0.0.4949] System.Net.WebException: Unable to connect to the remote server —> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 82.118.236.91:443
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
at System.Net.HttpWebRequest.GetResponse()
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse(HttpRequest request, CookieContainer cookies) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:line 95
at NzbDrone.Common.Http.Dispatchers.FallbackHttpDispatcher.GetResponse(HttpRequest request, CookieContainer cookies) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\Dispatchers\FallbackHttpDispatcher.cs:line 53
at NzbDrone.Common.Http.HttpClient.ExecuteRequest(HttpRequest request) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\HttpClient.cs:line 119
at NzbDrone.Common.Http.HttpClient.Execute(HttpRequest request) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\HttpClient.cs:line 55
at NzbDrone.Common.Http.HttpClient.Get(HttpRequest request) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\HttpClient.cs:line 220
at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider.FetchCapabilities(NewznabSettings indexerSettings) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:line 57
17-10-1 09:50:20.9|Warn|Newznab|Unable to connect to indexer
at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider.FetchCapabilities(NewznabSettings indexerSettings) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:line 62
at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider.<>c__DisplayClass4_0.b__0() in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:line 35
at NzbDrone.Common.Cache.Cached1.Get(String key, Func1 function, Nullable1 lifeTime) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Cache\Cached.cs:line 81 at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider.GetCapabilities(NewznabSettings indexerSettings) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:line 35 at NzbDrone.Core.Indexers.Newznab.Newznab.get_PageSize() in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Indexers\Newznab\Newznab.cs:line 22 at NzbDrone.Core.Indexers.Newznab.Newznab.GetRequestGenerator() in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Indexers\Newznab\Newznab.cs:line 26 at NzbDrone.Core.Indexers.HttpIndexerBase1.TestConnection() in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 315
