Sonarr version (exact version): Sonarr Ver. 2.0.0.5085
OS: Windows
Debug logs: https://pastebin.com/VjSxtdNr (I think I’ve copied whats needed, let know if I’m wrong)
Description of issue: When I try to start an automatic search for a TV episode, I get this first error, https://i.imgur.com/bWlIH7p.jpg , then eventually get this error following, https://i.imgur.com/qXkDSII.jpg . Sometimes everything will work fine, other times I get this error and can’t get sonarr to download anything.
18-1-26 19:09:11.1|Warn|HttpClient|HTTP Error - Res: [GET] http://127.0.0.1:9117/api/v2.0/indexers/ettv/results/torznab/api?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=100: 500.InternalServerError
"result": "error",
"error": "Exception (ettv): The remote name could not be resolved: 'www.ettv.tv': An error occurred while sending the request.",
Looks like Jackett failed to resolve the DNS record and it failed. Sonarr handled the failure and disabled the indexer temporarily in response to the failure. It’ll try again automatically, but if it continues to fail Sonarr will disable for a longer period of time on each failure.
It still isn’t fixed and still wont download any of my shows, is there any way to fix this?
You can test the indexer in Sonarr’s settings, but if it’s still failing it won’t fix anything. If it’ still failing you’ll need to see why it’s failing in Jackett and fix it.
this is the error I get in jackett
rror on 20180202230438 for EZTV.txtJackett.ExceptionWithConfigData: Got redirected to another domain. Try changing the indexer URL to https://unblocked.vc/.
at Jackett.Indexers.CardigannIndexer.CheckIfLoginIsNeeded(WebClientStringResult Result, IHtmlDocument document) in C:\projects\jackett\src\Jackett.Common\Indexers\CardigannIndexer.cs:line 703
at Jackett.Indexers.CardigannIndexer.<PerformQuery>d__28.MoveNext() in C:\projects\jackett\src\Jackett.Common\Indexers\CardigannIndexer.cs:line 1189
<html>
<head><title>302 Found</title><script data-cfasync="false" type="text/javascript">eval(window.atob("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"))</script></head>
<body bgcolor="white">
<center><h1>302 Found</h1></center>
<hr><center>nginx</center>
</body>
</html>
Error on 20180202230438 for EZTV.txtJackett.ExceptionWithConfigData: Got redirected to another domain. Try changing the indexer URL to https://unblocked.vc/.
This tells you here to try changing the Indexer URL to https://unblocked.vc/
Have you tried changing that setting in Jackett?
Tried this, just get “Found no results while trying to browse this tracker”
