Hopefully someone can help. Starting sometime Friday, anything being searched for fails with the following error:
Syntax Error after ‘<!’ characters. http://www.newzbin.com/DTD/nzb/nzb-1.1.dtd Line 1, position 3.
Within the GUI is appear like it just didn’t find anything. If you manually search or look in the logs you see this Syntax Error.
Here is small snipped of the debug log and the header from the NZB which is pulled down. This happens over and over.
thanks in advance!
18-5-19 08:03:09.1|Debug|Nzbget|Downloaded nzb for episode 'SHOWNAMEREMOVED ’ finished (142937 bytes from https://NAMEREMOVED/getnzb/a8976b77481b70ad2f21918133e87c0bfe982ba1.nzb&i=8832&r=5472905cadc7c575772d4a0dd6d09601)
18-5-19 08:03:09.2|Warn|ProcessDownloadDecisions|Couldn’t add report to download queue. REMOVED.real.720p.web.x264-tbs
[v2.0.0.5163] System.Xml.XmlException: Syntax Error after ‘<!’ characters. http://www.newzbin.com/DTD/nzb/nzb-1.1.dtd Line 1, position 3.
at System.Xml.DTDReader.CompileDeclaration () [0x00000] in :0
at System.Xml.DTDReader.ProcessDTDSubset () [0x00000] in :0
at System.Xml.DTDReader.GenerateDTDObjectModel () [0x00000] in :0
at Mono.Xml2.XmlTextReader.GenerateDTDObjectModel (System.String name, System.String publicId, System.String systemId, System.String internalSubset, Int32 intSubsetStartLine, Int32 intSubsetStartColumn) [0x00000] in :0
at Mono.Xml2.XmlTextReader.ReadDoctypeDecl () [0x00000] in :0
at Mono.Xml2.XmlTextReader.ReadDeclaration () [0x00000] in :0
at Mono.Xml2.XmlTextReader.ReadContent () [0x00000] in :0
at Mono.Xml2.XmlTextReader.Read () [0x00000] in :0
at System.Xml.XmlTextReader.Read () [0x00000] in :0
at Mono.Xml.XmlFilterReader.Read () [0x00000] in :0
at System.Xml.Linq.XDocument.ReadContent (System.Xml.XmlReader reader, LoadOptions options) [0x00000] in :0
at System.Xml.Linq.XDocument.LoadCore (System.Xml.XmlReader reader, LoadOptions options) [0x00000] in :0
at System.Xml.Linq.XDocument.Load (System.Xml.XmlReader reader, LoadOptions options) [0x00000] in :0
at System.Xml.Linq.XDocument.Load (System.Xml.XmlReader reader) [0x00000] in :0
at NzbDrone.Core.Download.NzbValidationService.Validate (System.String filename, System.Byte[] fileContent) [0x00000] in :0
at NzbDrone.Core.Download.UsenetClientBase1[NzbDrone.Core.Download.Clients.Nzbget.NzbgetSettings].Download (NzbDrone.Core.Parser.Model.RemoteEpisode remoteEpisode) [0x00000] in <filename unknown>:0 at NzbDrone.Core.Download.DownloadService.DownloadReport (NzbDrone.Core.Parser.Model.RemoteEpisode remoteEpisode) [0x00000] in <filename unknown>:0 at NzbDrone.Core.Download.ProcessDownloadDecisions.ProcessDecisions (System.Collections.Generic.List1 decisions) [0x00000] in :0
First line of the NZB which is is complaining about:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE nzb PUBLIC "-//newzBin//DTD NZB 1.1//EN" "http://www.newzbin.com/DTD/nzb/nzb-1.1.dtd">
<nzb xmlns="http://www.newzbin.com/DTD/2003/nzb">
