If you can tell me how to get what you need, I’ll do what I can to help.
I follow the logical steps, but really don’t know the details.
EDIT:
If this b/c a long term problem, then a work-around kludge would be to do automatic searches on all wanted eps on a recurring cycle. Say every few hours. Would NOT be optimal tho.
** slaps tymanthius for even suggesting periodic auto search **
Just grab the rss response, the url is in the hastebin dump, but please remove auth/passkeys before posting stuff (you already leaked the ttn keys, so reset those)
We clean as much as we can, pretty much all apikeys & passwords for supported indexers are properly removed, but this is a custom url in the torrentrssindexer, so a bit beyond our control But maybe I’ll add a few more queryparam keys to the cleanup routine… but I’ll likely forgotten all about it when I get back from holiday.
The hastebin log for awesome is not an rss feed, it’s the human readable part, missing the usual xml tags.
TTN giving no found is somewhat serious, but you should check their site to see what happened with the rss feed.
Just a quick update - disabled those, and everything is working. So it’s not a sonarr issue other than in that maybe failure handling could be improved.
Sorry about the bad pastebin - was at work & kinda rushed.
