Accessing NZBDrone from LAN
Hello,
I used to be able to access my other computer’s nzbdrone with a browser through the internal network (i.e. I type the ip of the computer along with the port).
For some reason that stopped working within the last couple of months. I’ve tried to look for any kind of settings but couldn’t find anything wrong. Sabnzbd works fine, so it has to be something special with the nzbdrone itself. Switching browsers had the same results (firefox vs IE)
Any ideas what might be causing this?
https://github.com/NzbDrone/NzbDrone/wiki/FAQ#how-do-i-access-nzbdrone-from-another-computer also check your Firewall.
Yes, I’ve tried that. That’s how I got it to work before, until it stopped working. Tried again, but it didn’t help.
Firewall shouldn’t be a problem since it is in the same LAN, also I assume sabnzbd wouldn’t work if the router would be the problem.
I’m referring to the firewall on the computer (not the router), be in Windows Firewall or something else (maybe it came with your Anti-virus).
