Hi,
Started using Sonarr reccently, but one thing that i think it really miss, is an ability to ensure that the value set in profile can also priority over release quality. - especially usefull when you want releases with subs
ill try to explain:
for a new serie,
- A 720p gets released, extra profile value 0 - Sonarr downloads it, as its not there.
- A 720p with subs get released, Sonar downloads it course profile indicates that value on “subs” is +1000 therefore better then previous.
- A 1080p eng gets released, extra profile value 0 - sonarr downloads this, and therefore deletes the subbed version
In step 3 it would be awesome if it allows for the quality to be lower due to the custom value of 1000 is higher then the new 1080p versions value, and that it would only change if a 1080p with subs came (that would also be +1000)
i would assume, that almost all users that grabs releases in their local sub language, would perfer a 720p with subs then a 1080p without subs ?
so basically, grab a release if availaible, stop at the highest release containing the custom keywords/values.
today i can make a nordic profile, but then i dont get the first english release.
if it makes sense
for showing it
example for will and grace, here the nordic version has +2000, but the 1080p release will get downloaded.
