I upgraded to 3.0.5 last night and freaked when after the upgrade completed, my install was none responsive. It was not responding on the port I assigned it to. Once I figured out it the install reverted back to it’s original port, and I connected to it, all shows were gone.
After some digging, seems when you upgrade using official ppa, the script changes the ExecStart line in /lib/systemd/system/sonarr.service. I don’t have my original anymore (as it’s gone now), but best I can figure is this :
Mine : ExecStart=/usr/bin/mono --debug /usr/lib/sonarr/bin/Sonarr.exe -nobrowser -data=/home/qbt/.config/sonarr
PPA : ExecStart=/usr/bin/mono --debug /usr/lib/sonarr/bin/Sonarr.exe -nobrowser -data=/var/lib/sonarr
Notice the difference in “-data”? This is the root cause. I had an old /var/lib/sonarr that was never used. I keep my data in /home/qbt/.config/sonarr (yeah I’m weird that way). For now, I’ve symlinked /var/lib/sonarr to /home/qbt/.config/sonarr. Restarted the service… all is back on the port I assigned the service to. If the PPA upgrades are actually messing with the ExecStart line, this a fix.
Suggestion: Please don’t mess around with “ExecStart” in PPA upgrades
