2nd Seasons Not Found
I’ve added Mom and Last Week tonight with John Oliver to Sonarr. In both cases Sonarr has downloaded most of the first season, but not the current (2nd) season. I’ve attempted to manually complete the search from the Series page, but still no luck.
Something I’m doing wrong?
Are the episodes monitored? If you do a full season search and the episodes aren’t monitored it won’t grab them. If you search for a single episode it will grab them though.
Check debug logs to see the result of processing each available release.
Thanks for the tip. I’ll check that out… Sounds like it could be the problem.
