Sonarr version (exact version): 4.0.18.2971
OS: Windows 10
Debug logs: PrivateBin
password: helpmesonarr
Description of issue: I have a 4k and hd versions of sonarr. Both were fine until the update before last I believe. Now, the HD 2nd instance no long connects to the same indexers that are still working fine on the 4k 1st instance of sonarr. All indexers provided by Prowlarr. I can fix the connect failures, but its fails again in seconds to minutes or after the first search requested.
anybody have any idea what’s broken?
The logs aren’t accessible, not sure if that was the case when I first looked, but please provide updated logs with a long expiry and no password.
Thanks for trying to take a look. I will repost the logs with a long expiration when I get home. I didnt realize that could happen. Thanks again!
The logs look to be filled with errors talking to your download client, uTorrent, which is throwing back 400 errors, not sure if Sonarr’s trace logs or any logs from uTorrent will have more information on the issue.
It’s also probably worth considering a newer client that has better automation support.
Thanks for taking a look. The identical settings work for my other sonarr instance, so not sure what it could be as it was working fine before, too. Hopefully the trace logs have more info:
2nd trace log where it looks like the problem is more visible with “Hacks” at the top of the log. Thanks again
qBittorrent or Deluge are your best choices. I recommend Deluge cause it’s easy just to grab it’s folder for backup and have your torrents start where they left off if you ever have to reinstall your OS.
