1080p being replaced with 720p
I have most of my shows downloaded in HDTV-1080p quality and would only want to re-download these shows if Bluray1080p was available. NzbDrone has recently started replacing my HDTV-1080p quality episodes with Bluray720p quality. I’m assuming that the quality ranking puts Bluray720p above HDTV-1080p, but personally I prefer HDTV-1080p and so this behaviour is not wanted.
What can I do to prevent this from happening? I know I could remove Bluray720p from the quality profile, but it would be good if there was another option so that shows where Bluray720p is the highest quality available (i.e. no 1080p at all) will be downloaded in Bluray720p.
Drone prefers better sources than resolution so for HD its:
HDTV 720p
HDTV 1080p
WEBDL 720p
WEBDL 1080p
Bluray 720p
Bluray 1080p
Even if it was possible to change the order (https://trello.com/c/dmuIBWwH/224-customize-quality-order) There wouldn’t be a way to support upgrading from HDTV 1080p to Bluray 1080p and only Bluray 720p if Bluray 1080p wasn’t available and as you said you prefer HDTV 1080p over Bluray 1080p.
Your only solution is to remove Bluray 720p.
Fair enough. Thanks!
