>100% CPU usage
Sonarr version (exact version): 4.0.11.2680
Mono version (if Sonarr is not running on Windows): Mono not installed
OS: Fedora Kinoite 41
Debug logs: Debug log - [Issue] over 100% CPU usage · GitHub
I have multiple *arr docker containers. Sonarr is the only one constantly hogging >100% CPU usage when I check docker stats. The issue started half a year ago and the version has seen several updates since then. I’ve also tried restarting the container, restarting docker, power cycling the computer and to no avail.
