Sonarr version (exact version): 4.0.4.1491
Mono version (if Sonarr is not running on Windows): on windows
OS: Windows 11 Pro
Debug logs: Sonarr Trace Logs
About 1 minute after grabbing a download, tv-sonarr uses 100% of my CPU and doesn’t stop. My computer literally grinds to a halt. Disc response time can be 3-5 seconds. I manually end Sonarr.exe and it is fine until it grabs a download again.
Radarr has the same issue, 100% CPU usage on radarr.exe after grabbing a release.
Both Sonarr and Radarr start the download and import the file just fine.
Radarr Trace Log
I have tried deleting files that were 0 bytes in size (corrupted?). I have also tried disabling authentication for localhost. Radarr, Sonarr, qbit are all up to date as well (qbit on v4.6.4). I have also tried stopping bazarr and Ombi in Task Manager to see if that was an issue.
I also use a VPN, Private Internet Access. Sonarr, Radarr, etc are in a split tunnel to use only the VPN, other apps will bypass the VPN. qBit has it’s Network Interface set to the PIA VPN (wgpia0).
All of the tasks under “System → Tasks” run fine as well.
Not sure what else to try, thanks for the help!
Here’s a snippit of the log for those searching for the error message:
|Info|Sonarr.Http.Authentication.BasicAuthenticationHandler|Basic was not authenticated. Failure message: Authorization header missing.
