Year in title causing problems parsing results from Jackett
The problem I am having is that the latest version of Sonarr is sending a year along with title to search index and Jackett is returning a lot less results
QUERY: Mayor S01E09 (previous versions)
Your search was done using: 1337x (6) , ETTV (2) , ExtraTorrent.ag (5) , EZTV (4) ,
vs
QUERY Mayor 2017 S01E09 (current version)
Your search was done using: 1337x (1) , ETTV (0) , ExtraTorrent.ag (1) , EZTV (1) ,
Is there a workaround for this?
This doesnt seem to be related to the year. I was comparing search results from ultraseedbox and vm that I built. Identical versions but ultraseedbox install is somehow sending 2 queries: with year and without year:
Feb 01, 2018 11:37:13 PM Info
Found 1 releases from EZTV for: Mayor 2017 S01E09
Feb 01, 2018 11:37:10 PM Info
Found 1 releases from 1337x for: Mayor 2017 S01E09
Feb 01, 2018 11:37:09 PM Info
Found 4 releases from EZTV for: Mayor S01E09
Feb 01, 2018 11:37:06 PM Info
Found 6 releases from 1337x for: Mayor S01E09
The VM install is sending 1 query, with year only.
What am I missing here??
The aliases (scene mappings) haven’t been pulled on the VM. I assume we’re talking about The Mayor (2017) - TheTVDB.com which has the title of The Mayor (2017) and also has an alias of The Mayor. If the alias hasn’t been pulled in from our server (it should have been unless it failed), then it won’t search for both titles.
