Yeah... so now what?
$20 sent. I’m impressed enough already to be comfortable with that. Hopefully it continues to impress and I continue to donate! (and hopefully others remember to do it too… there’s gotta be a TON of work going into this and you guys are FAR more responsive than most projects)
Thanks, much appreciated!
Hey Markus… did you deliberately fix the “bug” I reported here regarding the /mnt/lvm not reporting free disk space correctly (or at all)? Because whatever you did… it worked :slight_smile: I just now noticed that it is properly reporting. If you did something… good job! If you didn’t, then wtf? lol
Yes, I fixed it intentionally, ended up being pretty simple and the error was caused by a pretty obvious mistake when I looked at it.
OK. another newbie here, also will help with documentation for the weak at heart.
my first obstacle was to determine a directory structure. I am setting up a Media Server and so far have installed Win&, Sabnzbd , and of course NZBdroid… I have the intentions of "trapping movies in HD, and Cable Series"
any pointers to a “cheat sheet” approach
I assume you mean NzbDrone, not nzbdroid (very different applications).
This covers the sorting and renaming process once SAB has downloaded the file: https://github.com/NzbDrone/NzbDrone/wiki/Sorting-and-Renaming
You’ll need to setup a folder on disk where you want all your shows to live, something like: C:\\TV
Then on the add series page, add that folder as a recent/root folder and then add all your series under it
You’ll need to connect up SABnzbd as well, using the sorting and renaming wiki page as a guide for the drone factory folder setup.
That should be all you need to get started, but if you have any questions, let us know.
