XEM tends to have people screw up the databases because they can. Treehouse Masters on XEM is boinked. I had a HDD failure and redownloaded the whole series and every episode is 1-3 seasons off so went to http://thexem.de/xem/show/3644 which is the shows page and nothing is linked, even manual download isnt correcting when I select the correct episode.
Between XEM and and TVDB being ahem “difficult” it is getting harder to get anything from Discovery Networks to download. Damn discovery has a problem with changing season numbers all over the place like on Tanked - Animal planet says season 10, animal planet go says 12, and discovery says 9b. I would love an option to use SCENE/XEM/TVDB instead of relying on Sonarr to try and figure it out for me.
If I could set auto to use SCENE for certain shows or XEM/TVDB for others it would stop a lot of the issues people are having. Otherwise I have to go download each episode thru another program - rename them all correctly then copy to the correct folder each time I find this happening. Otherwise we post in freenode and hope someone answers…
