Sonarr version (exact version): 2.0.0.5054 Mono version (if Sonarr is not running on Windows): 5.0.1.1 OS: OS X 10.7.5 Debug logs: Not applicable to this question, will provide later if actual debugging needed. Description of issue:
Am I correct in thinking that when Sonarr is using a Xem mapping it shows an absolute episode number when you hover over the episode number?
e.g. the 2016 season of Mythbusters
This is currently not occurring with the new 2017 season (but it is showing a presumably âextrapolatedâ mapping):
This is with the mappings and show updated in Sonarr, no errors logged for those actions⌠but Iâm not actually sure if this is about Xemâs mapping or Sonarr.
Either way it causes the current season not to be foundâŚ
If it shows anything, then it is, the absolute number is irrelevant here since itâs not used for non-anime.
The issue is season 17 was used for a special, but the scene is actually using season 20 for releases, so the mapping on thexem.de needs to be updated.
