XBMC settings not saving
This had been working great until fairly recently. A few days ago I realized that my XBMC library stopped getting updated when new shows were downloaded. When I checked NZBdrone, the XBMC settings (IP, user, pass, etc) were missing. I re-entered them, verified the connection and clicked save. When I refreshed the page and checked again, the settings were missing. I have tried this several times and every time the settings disappear. Anyone else running into this?
Thanks!
john
I also just noticed when I do a test on mine I get the following error. I am getting the same error when I do an email test:
EditView.js : 76
TypeError: _ is undefined
I never had this issue before.
Yeah, this snuck through the develop branch and made it into release. I’m working on a fix now, should have it to develop soon and master after it gets some testing on that branch.
Testing is already fixed, I just need to push it up once I fix this saving issue.
Thanks
Thanks!
Pushed the fixes up to the develop branch, if you guys could both update and test that would be great.
i hadn’t noticed it but i am on the service-dependencies branch still testing that issue out for you but still glad this is sorted because it is a feature i also use with my xbmc machines :slight_smile:
XBMC notifications works for me but Email notification doesn’t.
It works great now. Thanks!
shedrock, whats the issue with Email? If its the same error as above, you will need to refresh the UI for the UI changes to take effect.
My apologies. I was looking at my wife’s phone for the email test results instead of mine. It works just fine now.
