XBMC Connections Ignore's "Always Update" setting
XBMC Connections Ignore’s “Always Update” setting,
i’ve set it to “No” so it won’t update during a play.
but it seems to ignore it and still updates it with the notification in XBMC during play
The notification and updating are separate, it will always send the notification regardless if video is playing or not. The update will only trigger if a video isn’t playing (it will trigger if music is playing).
I verified that its not updating when a video is playing.
hmm,
weird.
i was watching a TV serie yesterday and it started to send and execute a clean command to XBMC.
If you notice it happening again debug files from drone are very useful, as well as the drone version and XBMC version.
