i previously had WWE RAW added to Sonarr that i set up for my brother,
and it was working (more or less). but recently i decided to delete the WWE RAW entry, and re add it.
only now i cant find the damn series i had added.
if i search +Add series “Monday night raw” all i get is the 2 TVDB entries. i dont maintin his server too often so i cant remember if i did a work around to add the up-to-date series entry to his Sonarr.
does this ring a bell with anyone? was this issue solved? was there Raw under a similar name? if so i cant seem to find a solution even though i just had it working.
