The scene info to the show “The Last Leg” is wrong. Every one of the meta trackers (trackt, tvdb, etc) all confirm what the TV metadata says that it is season 9 however it has a yellow ! saying Season 10 inside the season 9 banner.
Is this something that Sonarr staff can fix?
JUst editing to say that this IS Season 9, as the TV guide confirms this. There was a special series which some have called season 9 i guess but it was special not the actual season.
That series is remapped on thexem (used when the scene isn’t following the TVDB numbering), which is explained in the FAQ.
Sonarr is making an educated guess that the scene numbering is continuing into season 9, but it is not currently mapped on thexem (but will need to be since the numbering conflicts in earlier seasons), because Sonarr is making that guess it shows with the exclamation mark.
It looks like Sonarr’s educated guess is correct, but thexem will need to be updated, otherwise you’d end up getting releases for season 8 because they are released as season 9.
The yellow exclamation mark is wrong, so the educated guess is wrong. as Season 8 is showing as season 8 (correct), but because they had a 14 run special for the Rio Paralympics, this was put as special episodes, and we are currently in to season 9 (scene thinks it might be 10)
Every indexer has them marked down as season 9 and when I download one from S9 it comes as S9.
Looking at that link you provided (thanks for that) it is clear TVDB has the S0 (specials) then S1 but does not have S9 at all, however Scene and Xmaster do but don’t have S0. Is this something that is easy to change or is this a case of hoping they work it out soon enough and hope it won’t interfere with any future seasons? Thanks
XEM also has it as a US show when its a UK show too. Nothing I know SOnarr can do about that but I hope it won’t impact on future downloads.
Season 8 (TVDB) is mapped to season 9 (Scene), which looks correct given the releases for season 9 are 110+ days and look to match the season 8 episodes.
The.Last.Leg.With.Adam.Hills.S09E01.Russell.Crowe-Jeremy.Corbyn.PDTV.x264-CBFM 111.8 days old (2016-08-11) which matches the description of TVDB’s S08E01: The first guest of the series, Labour Leader Jeremy Corbyn and Hollywood star Russell Crowe, joins the team to examine the biggest and most entertaining news stories.
If any changes need to be made you’ll need to reach out the the team that manages them on IRC, listed in their FAQ. http://thexem.de/faq
That’s a language flag, they use the US flag for English.
Thanks for that. Is it safe to assume that I won’t have any future problems with downloading it? I have had issues due to lack of availability but that has been solved for me going a different route but I was able to pick up a few episodes via Sonarr normally. I was not sure if they were linked.
