Hi all,
Sonarr seems to be displaying some wrong posters in the shows view.
Some of the images are correct some not, for example dads army shows the image of due south, but when you go into the series, the background image is correct l I’ve tried deleting the mediacover directory contents, no images, and doing a rescan, some right some wrong.
If they are wrong after deleting the media cover folder and rescanning either Sonarr is being told to grab the wrong ones because they are wrong on TheTVDB or something is caching them (a browser extension). Try another browser/private browsing, also knowing a couple shows that are wrong would be helpful in diagnosing.
What an interesting problem. You are quite right. I had issued the rescan from my ipad. I deleted the MediaCover again, and issued the rescan from my laptop with chrome, and it worked fine. There are a few missing ones, but no doubt it will pick them up and if not I can add them. Thank you for your help.
Could we add this as a known issue with Safari to help the next person?
