Sonarr version (exact version): 2.0.0.5228
OS: Windows 10 Pro version 1809 (OS Build 17763.1)
Description of issue: Sonarr has a different episode numbering than TVDB. The Good Place for example puts Season 3 episode 1 “Everything is Bronzer” with running time of 43 minutes counts as 1 episode on TVDB but the indexers are putting episode 1 as 2 episode but TVMaze is also putting episode 1 as 2 episode namely “Everything is Bronzer Pt. 1 & 2”. Download for episode 2 is now on episode 3 “The Snowplow”. Encoders are not following TVDB but TVMaze, Sonarr follows TVDB but not TVMaze. I am confused. Which one is it?
Hi Markus
WEB-DL’s by P2P are matching the TVDB but Sonarr is using the scene TV mappings from the XEM.
How can we sort that? It downloads the wrong files which screws up the seeding.
Thanks
That’s not possible, mappings always apply, it’s not possible to only have them apply for some qualities.
