Hello Com,
i came from Sickbeard and will test this great looking tool. For the most series it works, i can find it. But with
Gomorrha and The Musketeer i can found it on thetvdb.com but your tool not. So what can i do ? Or what is my mistake ?
Then i have little OFF TOPIC quest’s.
First, how is saved the nzb file ? And second quets, when i understand it right, there is no automatic search for series ? When i add an older series and i do no manual search it would not search from alon for example all 2 hours or days ? I think this is calling backloc search, right ?
Greet’s and thanks for read !!
You can add it by TVDB ID if you can’t find it by title.
NZBs are sent To your download client (whatever you configure in Sonarr).
Sonarr won’t search the indexer looking for those missing episodes, but will use the RSs feeds from the indexers to find them (if they are reposted). https://github.com/Sonarr/Sonarr/wiki/FAQ
Hm i try to add this series with the tvdb ID but there came the same message, that he can’t find the series.
So for better understanding, i have to search manual Ehen i will have the episodes ?
You need to use tvdb:12345
(where 12345 is the ID from TheTVDB)
From the UI:
You can also search by tvdbid using the tvdb: prefixes.
You will have to click search within Sonarr, either using the manual search or automatic search options (episode level) or search at the season/series level.
