Workaround for Issue #899?
Good morning,
Just a quick question. I seem to be experiencing the bug that has been reported in issue #899 (https://github.com/Sonarr/Sonarr/issues/899). Is their an easy workaround for it, or do I need to go through each series individually to make sure that it’s correct?
Thanks in advance for your help.
Cheers,
~Spritz
Either manually or try to do it in the database, but there isn’t an easy way to get the monitored status of a particular season since they are stored in the series table as JSON and not in their own table.
Depending what you want to do you could update all episodes or all episodes before a certain date and optionally with or without a file.
