The error
[Warn] NzbDroneErrorPipeline: Invalid request Validation failed:
– Folder is not writable by user me
My setup
- Sonarr on a laptop running Ubuntu Gnome 16.04
- 3TB external HDD connected to a Mi Box 3 (Android TV)
My problem
I can read my HDD files remotely on my laptop using FTP (ES File Explorer function). Android TV somehow can’t write to NTFS disks.
I want Sonarr to check these folders and see that I already have those files. So these files would not be labeled as “Missing” on my laptop. But Sonarr won’t import TV Series from unwritable folders.
Suggestions
- Remove prerequisite “write permission” from library folders. I can manually handle copying / moving files as I have done my entirely life.
- Check library info from Kodi to not label files as “Missing”.
- Add remote library (via FTP, SSH, SMB, HTTP etc) and ignore copying / moving files to these folders.
P.S.: I know FTP isn’t safe. So using library info from Kodi would be the best solution.
P.S. 2: Once I get a backup device, I’ll try to find a way to make Android TV allow access through SSH or SMB.
