Where do these options match up after adding a series?
When adding a new series you are shown a dropdown that says “Monitor”
I see no one place where this exists after adding a series, so I was wondering how/where these options match up to other options? If that makes sense.
eg. The option “None” I would assume is equal to > “Monitored” > “No”?
Would “All” be “Edit Series” > “Monitored” > “Yes”?
What about the rest?
EDIT: Would it be feasible to just add that same dropdown to the “Edit Series” section?
Thanks,
Derek
It will be added to Season Pass in a future release, but its not going to be added to edit series because its not a setting on the series, but something that is applied to seasons/episodes in the series (one time).
When you select none it is effectively ignoring all seasons, which in turn ignores all the episodes, but you could achieve the same thing by unmonitoring the whole series. First and Latest season both apply to seasons, where the first or last season (respectively) is monitored and all other seasons are unmonitored. Future, Missing and Existing apply to the episodes once the episode information has been loaded, ignoring all aired episodes, all episodes without files (including future episodes) and only episodes with files, respectively.
So after I initially set the monitor option, where do I go to change what is monitored? Specifically Future, Missing and Existing?
There’s a bookmark icon on the series, season and episode level in front of the title.
so to monitor only future, i have to go to each season and toggle season monitor status but leave toggle series monitored status?
At the moment yes, but we’re going to replicate the future/missing logic to season pass, its being worked on, but not yet complete.
