Sonarr version (exact version): 2.0.0.5228
OS: Server 2016
Description of issue: I pain stakingly went through and “Un Monitored” all the shows that have ended, but Sonarr is still searching each of the series. Its is currently searching 647. Is this normal?
Sonarr doesn’t search for anything on it’s own unless it’s looking for a replacement for a failed download.
Sonarr will process RSS results looking for things you want, even if they aren’t monitored (because it has no way of knowing it’s not wanted until it processes it).
Makes since … Thanks for the response.
