What are tags used for?
Not sure what tags are used for. I noticed that it was added as an update recently. Can someone please tell me what they are used for?
Its list in the change log for 2.0.0.2171:
Ability to tag series
Use tags to control which series use which notification channels
Not to hijack but this kinda goes along with the OP question…
I assume in the notification section, if you leave the tags field blank, it’ll notify for everything?
Let me clarify: I have kid shows that I don’t want my main XBMC systems popping up with snagging/downloading. If I leave the tag blank, it appears that it notifies anyway. So, in effect, each series I have, a tag would need to be set, correct?
If that is the case, I assume a mass edit will be added when you guys get time to change the tag across multiple shows at once instead of individually?
LJ
Blank = everything. If a series is tagged and the notification is blank it will send, but vice-versa it would not, same as if a the tags on a series didn’t match the tags on a notification.
Yes, there will also be more things that utilize tags.
awesome markus. Great feature as I didn’t have an automatic solution before to auto update the kid shows in XBMC… now, I do :slight_smile:
LJ
