What am I doing wrong? File and folder saving problems
I’m a bit anal, but I prefer my folders to be saved in a certain way.
What I want is something like this:
Media/tv/Show/Season #/Show - S##E## - Show name (if applicable)
Instead, after a while I get something like this http://i.imgur.com/D3UQ3gZ.jpg
Should just be 14 folders, but all the extra folders are episodes of shows I have downloaded.
Another thing, I keep getting empty folders in some of the original 14 shows folders, how would I go about automatically deleting those?
Thanks
Separate your sorted and unsorted files. Sounds like Sonarr isn’t sorting files, you’ll have to check to logs to see why.
