docker container linuxserver/sonarr which is Sonarr Ver. 2.0.0.4949
OS:
Docker (with Ubuntu Xenial as a base)
((Debug logs)):
17-8-22 15:49:01.3|Debug|Torznab|Downloading Feed http://jackett:9117/torznab/all?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=100
17-8-22 15:49:01.5|Warn|NzbDroneErrorPipeline|Invalid request Validation failed:
– No results were returned from your indexer, please check your settings.
17-8-22 15:49:01.5|Debug|Api|[POST] /api/indexer/test: 400.BadRequest (328 ms)
When manually curling the jackett api from my sonarr server, it returns results:
root@6ba2f47d12e1:/config/logs# curl http://jackett:9117/torznab/all?apikey=jwwys3yc0ax0olheftmb8dbhhekv7cb3 | head -100
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 <?xml version="1.0" encoding="UTF-8"?> 0 --:--:-- 0:00:11 --:--:-- 0
<rss version="1.0" xmlns:atom="http://www.w3.org/2005/Atom" xmlns:torznab="http://torznab.com/schemas/2015/feed">
<channel>
<atom:link href="http://jackett:9117/" rel="self" type="application/rss+xml" />
<title>AggregateSearch</title>
<description>This feed includes all configured trackers</description>
<link>http://127.0.0.1/</link>
<lanuage>en-us</lanuage>
<category>search</category>
<image>
<url>http://jackett:9117/logos/aggregateindexer.png</url>
<description>AggregateSearch</description>
</image>
<item>
<title>Game.of.Thrones.S07E06.1080p.WEBRip.x264.LEGENDADO-WWW.BLUDV.COM.mkv</title>
<guid>https://torrentz2.eu/0111c660685693c4b7d8afbdfb5aae4121feb453</guid>
<comments>https://torrentz2.eu/0111c660685693c4b7d8afbdfb5aae4121feb453</comments>
<pubDate>Tue, 22 Aug 2017 15:31:07 +0100</pubDate>
<size>1955594240</size>
(and so on)
But looking at the debugging logs, it’s trying to run the following command, which gives me this output:
root@6ba2f47d12e1:/config/logs# curl http://jackett:9117/torznab/all?t=tvsearch&cat=5030,5040&extended=1&offset=0&limit=100&apikey=jwwys3yc0ax0olheftmb8dbhhekv7cb3
[1] 491
[2] 492
[3] 493
[4] 494
[5] 495
root@6ba2f47d12e1:/config/logs# "Incorrect API key"
[1] Done curl http://jackett:9117/torznab/all?t=tvsearch
[2] Done cat=5030,5040
[3] Done extended=1
[4]- Done offset=0
[5]+ Done limit=100
If I then remove t=tvsearch&cat=5030,5040&extended=1&offset=0&limit=100&
from the command, it returns results.
Does anyone have an idea of where I’m going wrong here?
