version 2.0.0.5
Up to date, just updated it
OS:
Linux Mint
Debug logs: http://pasted.co/fbe284f3
Web GUI will not load. Just continues to attempt to load. Any help would be appreciated.
FWIW the exact version is significant, though it’s in the logs in this case. As is the mono version, sometimes there are bugs we know exist in certain versions.
The DB is corrupt and there are a couple ways to address it:
- ((Restore)) a backup
- Fix the issue manually in nzbdrone.db using a SQL editor,
UPDATE Series SET LastInfoSync = null
and then refresh all series
Thanks Markus, editing the database did it.
I will try to be more clear in the future. I appreciate the help.
