**Sonarr version (2.0.0.3953):
**Windows 10:
**Copied file in TV folder cannot be deleted
OK, I’m using Sonar and uTorrent to download the files. Sonar copies (and renames) the files to my TV Shows folder and I stream them to my Android TV box using Plex Server on Windows, and Plex Player on Android. This works just fine 98% of the time.
I’m not someone who keeps a video library, so when I’ve watched a show, I generally delete it using the Plex Player support to delete it from the Windows file system.
This works fine mos of the time, but once in a while, the delete fails.
I go to the Windows system to do a manual delete, and Windows says it cannot delete it either because it is held by uTorrent
How can uTorrent be holding it? It has a totally different name than the one uTorrent created in the download, the name is the one Sonarr used when it copied it.
So this is not a repeat of the problems in deleting the uTorrent downloaded files, these are the files created by Sonarr.
But if I re-cycle uTorrent, I can then delete the file just fine.
Weird. Any thoughts on just what is going on?
George
