Sonarr version (exact version): 3.0.3.721
Mono version (if Sonarr is not running on Windows):5.20.1.34
OS: 3.0.3.721-ls182 by linuxserver.io Docker
Just curious as to why some titles show the audio codec as “True HD 8.0” when others (even in the same season!) show as “TrueHD Atmos 7.1”. I know all are technically Atmos 7.1.
Here is the output from episode 1 which shows as True HD 8.0:
Audio
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Duration : 1 h 9 min
Bit rate mode : Variable
Bit rate : 2 799 kb/s
Maximum bit rate : 4 158 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Delay relative to video : 1 s 1 ms
Stream size : 1.36 GiB (45%)
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
…and E2 which shows as Atmos 7.1:
Audio
Codec ID : A_TRUEHD
Duration : 57 min 49 s
Bit rate : 2 772 kb/s
Maximum bit rate : 4 170 kb/s
Stream size : 1.12 GiB (39%)
Language : English
Default : Yes
Forced : No
Kev.
