**Sonarr version 2.0.0.5252
OS: Microsoft Windows [Version 10.0.17134.523]
I have been using Sonarr with API calls to NZBNDX for over a year without problems. Recently, not sure whether it was at the upgrade to 2.0.0.5252 or earlier API calls are failing.
Debug log says:
19-1-19 11:43:13.8|Trace|Http|Req: 577 [POST] /api/indexer/test
19-1-19 11:43:13.8|Debug|Newznab|Downloading Feed https://www.nzbndx.com/api?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=100
19-1-19 11:43:13.9|Trace|HttpClient|Req: [GET] https://www.nzbndx.com/api?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=100
19-1-19 11:43:13.9|Trace|ConfigService|Using default config value for ‘proxyenabled’ defaultValue:‘False’
19-1-19 11:43:14.3|Trace|HttpClient|Res: [GET] https://www.nzbndx.com/api?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=100: 200.OK (475 ms)
19-1-19 11:43:14.3|Trace|NzbDroneErrorPipeline|Handling Exception
19-1-19 11:43:14.4|Warn|NzbDroneErrorPipeline|Invalid request Validation failed:
– No results were returned from your indexer, please check your settings.
19-1-19 11:43:14.4|Trace|Http|Res: 577 [POST] /api/indexer/test: 400.BadRequest (547 ms)
19-1-19 11:43:14.4|Debug|Api|[POST] /api/indexer/test: 400.BadRequest (547 ms).
Not sure if this is a Sonarr problem or an NZBNDX problem. API calls to other Indexers are OK.
